KINGSTON BRASS VTDS673023H5 KINGSTON BRASS 67 IN. DOUBLE ENDED ACRYLIC TUB WITH OIL RUBBED BRONZE CONSTANTINE LION FEET WITHOUT 7 IN. CENTERS DRILLINGS WHITE
67 in. double ended claw foot tub is constructed of a high quality acrylic material. This allows the tub to be moved easily without the concerns of conventional cast iron bathtubs. Pamper yourself with the spaciousness this tub has to offer. With no faucet drillings match your home décor by installing either a freestanding or home wall-mounted tub filler.
Features- Durable Acrylic Clawfoot Tub
- Overall dimension - (L)67 in. x (W)29-3/8 in. x (H)22-5/8 (± 1/2 in.)
- Smooth And Easy To Clean Porcelain Enameled Surface
- Porcelain Over Acrylic Prime And Painted
- Feet are Powder coated Over Aluminum
- Feet with built in adjuster that allow for use on uneven floor
- Feet Finish - Oil Rubbed Bronze
- Color - White
Price: 1601.28
