JEWEL FAUCET 16711RIT-21 HIGH FLOW THERMOSTATIC VALVE BODY AND J16 SERIES TRIM OIL RUBBED BRONZE DESIGNER FINISH
The showpiece of any bath presents this Attractive Single Handle high flow 3/4 in. Thermostatic Faucet with temperature control for multiple outlets. Use a separate stop/volume control (16402RIT) for each outlet. Designer Finished trim and valve body included. This faucet has solid brass construction and smooth operating ceramic control for reliable service while maintaining mixed water temperature as set. This sleek and simple series can be described as minimalist for the modern. Combining simple forms with sensual design Series J16 proves that less can definitely be more.
Features- Designer contemporary style adds a unique flair to any home.
- Durable and attractive PVD Finish.
- High Flow Thermostatic valve.
- Large 3/4 in. Valve supports multiple ports.
- Individual volume controls and diverters necessary for each shower outlet.
- Valve body includes integral stops to meet code requirements.
- Thermostatic valves accurately regulate temperature and prevent thermal drift.
- Heavy Solid Cast Brass Construction.
- 9.7 Gal/Min. Max at 60psi.
- Collection Name - J16 Bath Series.
- Designer Finish.
- Decorative Finish - Oil Rubbed Bronze
- Dimension - 11 L x 8 W x 7 D in.
- Item Weight - 6 lbs..
- Made in Italy.
Price: 705.46
