JEWEL FAUCET 11711RIT-68 HIGH FLOW THERMOSTATIC VALVE BODY AND J11 SERIES TRIM POLISHED NICKEL DESIGNER FINISH
The showpiece of any bath presents this Attractive Single Handle high flow 3/4 in. Thermostatic Faucet with temperature control for multiple outlets. Use a separate stop/volume control (11402RIT) for each outlet. Designer Finished trim and valve body included. This faucet has solid brass construction and smooth operating ceramic control for reliable service while maintaining mixed water temperature as set. Series J11 combines beauty and function in a harmonious fashion. The fresh arching spouts are both simple and technically established innovations that allow this line to rise above the rest.
Features- Designer contemporary style adds a unique flair to any home.
- Durable and attractive PVD Finish.
- High Flow Thermostatic valve.
- Includes In-Wall Valve Body and Trim.
- Valve body includes integral stops to meet code requirements.
- Thermostatic valves accurately regulate temperature and prevent thermal drift.
- Use with stop/volume control 11402RIT for each set of outlets.
- Heavy Solid Cast Brass Construction.
- 9.7 Gal/Min. Max at 60psi.
- Collection Name - J11 Bath Series.
- Designer Finish.
- Decorative Finish - Polished Nickel
- Dimension - 11 L x 8 W x 7 D in.
- Item Weight - 7 lbs..
- Made in Italy.
Price: 811.54
